I've had a quick look around the forums but can't find exactly what I am looking for.
First, what is the offset for the wheels on an R32 GTR? I desperately need 17" or 18" but I keep getting different stories about what wheels will fit.
Also, does anyone know where I can pick up a reasonable front bar for a 32 GTR? I have been searching for months and I can find a ton of GTR bars for GTS-T's but try finding one for an actual GTR!
Any help appreciated.
https://www.sau.com.au/forums/topic/87285-two-quick-r32-gtr-questions/
Are you sure? Try sticking a GTS-T wheel on a GTR, the difference seems a lot greater than that.
yes, i'm sure.
I have R33 GTR wheels on my gts and also have a set of stock wheels.
the difference is the width of the rim.
R33 GTR 9 inch
32 GTS 6.5 inch.
Make sure you get the fitment to suit bigger brakes. Most of the japanese wheel brands I have searched have 2 different fitments, but alot of cheaper brands will not. I'm in the process of trying to find some nice rims for my 32 GTR as well, good luck with it :mellow:
Just to confirm, MrZac from Slidewize concurs BNR32 offset is +12 to +22. There was a thread about this a few weeks ago. Danny, Ronin09 and lwells were all posting interesting bits and pieces but cant seem to find it through a search. I can't remember who but one of the guys was planning on fitting R34 wheels to his R32.
And when you have it all sorted, be sure to make a post in SK's sticky in the Susp,Tyres,Brakes folder! :)
not long sooty, don't know where it went with the transition though... will zip it and add it as an attachment in a sec.
*note this is a guide - use at your own risk. Always consult a wheel expert before making an offset decision. :P
hmmm
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
