Indicators Blinking real fast!
Well i had to pull my front 400r bumper off to fit my new cooler and in the process 2 of the bulbs in the indicators on the bumper broke, so i replaced em with new bulbs. We had to remove the fan for the AC also cause it was in the way of the cooler. Now my indicators blink real fast like there is a bulb not working, but they all work fine. Could it be caused by the plug for the AC fan being left off cause it was removed and its detecting this as a fault!
Here a pic of the front bar and cooler for those that havent seen it yet!
Oh and i got 183kw@wheels at 0.9 bar boost after the s-afc was retuned with the new cooler
https://www.sau.com.au/forums/topic/8753-indicators-blinking-real-fast/
Sure you replaced them with the correct wattage bulbs. I think the rapid blinking is caused by the system detecting the wrong voltage drop, which will vary according the the wattage of the globe. I can't see how the A/C fan would affect the indicator voltages. Otherwise you'd get different blink rates when the fan was on and when it was off.
i am preety sure i replaced em with the correct bulbs. How many different wattages do they come inm they r the 1'c with the 3 lipped end. Does the left and right indicators run off the same circuit so if 1 of the left bulbs r not working the blinker will still bink fast even when u indicate right?
heres my dyno graph 2!!
The increase in blinker speed is caused by a bad/faulty/short circuit
Same thing happens if you forget to connect your driving lights back up when you take the front bar off.
Sounds like your bulbs are incorrect
Originally posted by INASNT
no not yet, but i changed my headlight fluid and it didnt help either!!! :D
yeah? well give it a go dude...
It's probably the blinker fluids..and don't try and use the headlight fluid for the blinks, it will stuff things up...
Good luck with it :D
I did the same thing and they blinked too fast, either get the correct wattage bulb or place a resistor from Dick-Smith in series with the bulb, this will give it the correct volt drop and they should blink normal.
See'ya:burnout:
when i was working with cars and puting them back together and doing panel beating this was common... mainly cause one of the lights (as they run in series) isnt working.
when one stops working or blows then it puts the series out and starts to flash faster but generally only on the side which the bulb is affected.
Inark,
Normaly that is the case, that one of the lights has blown, but if you put in the wrong wattage globe then that has the same effect. Need to increase the resistance of the line back to what the original system was by adding a resistor.
See'ya:burnout:
can any 1 give me the correct wattage for em. And remember its the 1'c on the front bumper. Thanks
Here is !! :P:D
Copied straight from my Skyline manual.
Head Lamp 12v 55w
Fog Lamp 12v 35w
Side Lights 12v 5w
License Plate 12v 5w
System/Rear Lights 12v 21/5w ???
Reverse Lights
Sedan 12v 18w
Coupe 12v 21w
Indicator Front 12v 21w
Rear 12v 5w
Cornering Lamp 12v 21w
So front bar indicators should be 21 watties.
J
Originally posted by Jay95R33
Here is !!  :P  :D
Head Lamp              12v  55w
Fog Lamp                 12v 35w
Side Lights               12v 5w
Reverse Lights
        Sedan        12v 18w
        Coupe        12v 21w
              Rear     12v 5w
J
thanks jay!
Originally posted by GTS-t VSPEC
Jay,
You have a Skyline manual, how did you score that?
See'ya:burnout:
:P :P
It's just the owners manual... Not the workshop manual :P
I'd looooove to get hold of a workshop manual.
My last cars I'd always get a Gregory's manual so I could work on the car myself. With the Skyline I'm a bit nude, but willing to get in there and give it a go.
J
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
