i did the comp test after i noticed it was filling. I was more concerned when my car blew white smoke for a while...but i think that was due to the catch can being overfilled..
So can a leak down test find out that a comp cant?
Yes
  • Replies 90
Leakdown test can tell you if your engine is leaking compression be it past the rings, past the valves etc. Can also tell you if the head/head gasket is damaged at all (take the radiator cap off when you do it, and if it blows coolant out then you have a head problem).
It's blown.
number 6 has half the compression of the rest.
Wow...
That's surprising from a little overboost. Depending how much you turned up the duty cycle of your boost solenoids, when that leak closed up again and gave proper duty cycle, surely it wouldn't have overboosted *THAT* much :D
Oh well... Welcome to the club :D
I think it probably hit about 1.1-1.2 bar. We all already knew there was a lot of timing in that mid range.
Yes the engine was bmanned/dmanned/mmanned/amanned.
I join a club that many of my friends have been members of for some time. Oh well. Bring on the forgies.
  • 2 months later...
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
