Yes you can fit 20" rims on an R33 !! Jonny from Tempe Tyres had 22" rims on his R33 ( no idea of the offset etc. ). I must say though, 20"+ rims and Aussie roads are SO NOT suited IMO. And also ( IMO ), the only car I've seen that looked "correct" with 20"+ rims was a Lexus. But, whatever pushes your buttons.............. ;)
i love my 20s i wouldnt go any smaller
im almost 100% tempe only had 20s on the silver R33 GTR plates were WHYTRY that was the biggest AMEs ever came in
in not sure if they would fit on an R33 GTSt
but i guess it all depends on how much your going to lower it
i think 245s will be too wide for the rear
but as long as you dont drop it on its guts 225 should be ok for the front assuming you have the right offset
get ur 20's dude, they'll look hot, just dont expect them to do any favours for your handling or your wallet ie tyres cost more and wear shitloads quicker on the insides than more regular sizes. After having 19's, I wouldn't go anything over 18's on any car that I ever wanted to actually handle now... except for maybe an X5 or somethin :P
get em dude, or you'll want them forever just like I did!
not really champ
everyone has different tastes some people like 20s and chrome wheels and some dont
i dont have 20s cause im an attention seeker i have em cause thats wat a like and thats the way i want my car to look
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
