Hi Gents,
Now that I have my shiney new Splitfire Coil Packs (Big Thanks to the guys at Kudos Motorsports) I need to fit them.
My current plugs are gapped at about 0.7-0.8mm.
What should I gap them too?
Would 1.0 - 1.1 be about right?
BASS OUT
https://www.sau.com.au/forums/topic/87888-plug-gaps-and-splitfires/
If its any interest to anyone, i've tested my std gtst old coils and the new splitfires, and aside from the primary winding resistance being .6 ohms against the stock ones .7 ohms, the secondary coil current is the same as the stock old ones(1.4ma). Also the spark gap they will jump is also the same.......(18mm)
This was using a set frequency coil tester, around 50 - 60 hz odd...... for 9000 rpm the freq would be 75 hz, so pretty close. stock coil might drop off abit at high freq, but i dont think its as much as they seem to indicate.
Anyone else done testing to argue otherwise ?
Gary
Gary
I don't even know what you're on about, how can I argue? :lol:
They only reason they "seem" much better is a lot of people buy those as opposed to ones off Nissan which probably is more expensive.
I dont think they are any different to stockers... its just that they are a cheaper brand new alternative
A Brand new coil pack is going to be better than one that is 5/10/15 years old
Yeah that was my asumption too, there just a blue version of a new coil basically...... there are minor diferences in the primary resistance, and also the core seems to be two E cores instead of all joined together. (ie the metal former is not joined on the sides)
I assumed this when buying them, but since there new and cheaper than nissan, there the ones to get.
I would think all the guys who report more power have old coils starting to break down internally , and worst case externally arcing onto the coil brackets.
Only way i'd believe these are better is run a car on brand new nissan ones till it was blowing the spark out at a certain gap, then swap these in.... but i doubt there would be any gain on new coils.
For interests sake i also tested the secondary current of some other coils .
gtst - 1.4ma
bosch mec 718 2.1ma
S4 rx7 trailing 2.9 ma !
Gary
Thats exactly what ive been thinking for along time ;)
my coils started arcing to the brackets (at least three of them) and as has been mentioned i bought the splitfires because they were cheaper than nissan ones. they look exactly the same, and i can tell you that there was definetly NO power increase when compared to my stock coils when they were working properly ;)
and talking gaps, with my splitfires i have run both coppers and iridiums with the standard 1.1 gap with no problem, but only at 10psi.
Wow I thought we were gettin extra juice outta these Splitfires.... Ripped off!! Just like thier friggin spark plugs..
well talking plugs, i swapped old (40,000kms 2.5year) iridium ix plugs which looked fine for new coppers, no difference. i only changed them because they were old...
i believe the standard coils in conjunction with being old somehow get damaged inside after being exposed to a lot of heat.
mine started arcing all of a sudden, within days after i went to a skidpan day(refer to picture ;) ), lots of sustained high revs, and it was a very hot day
I found a 10psi 1.1 mm gap was fine on irudiums
but
at 14psi it was blowing out spark.... If i reduce the gap to 0.8 then i get a small flat spot where there is too much fuel and its drowning the spark bsiclly.... So im gonna toss out the split fires and run after market coil packs and spark plug leads....
Should reduce the heat issues these things have also....
$600 for a set of split fires.....
vs.
$400 for a set of 3 double packs from bosch and $100 on a set of leads from autobarn....
Much the same price but i know which will do a better job....
Remember this one basic rule....
If you want more power you need...
1. More fuel (040 fuel pump and bigger injectors and maby a fpr)
2. More air (turn up the boost)
3. More ignightion (bigger plug gaps and more power for the spark)
If you dont increase each evenlly you will have trouble....
i got 3rwkw increase on back to back dyno runs just by changing to the splitfire coils, which im not claiming is reason to go out and buy em! my std ones were getting temperamental.
Plug gap had to remain at 0.7mm otherwise id get missfires at 1.2bar.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
