Hi Skyliners,
I've gotta few problems with my front suspension. Would like to share with you for some tips, advise and ideas:
1) Its making a squarky noise. The mechanic said it has worn out and advised me to change it. He said its not urgent and does not need replacing if I'm not driving my sky hard. Would like to know what brand and price range am I lookin at to replace the 4 shocks system.
2) My brake pads is very low. Would like some recommendation on brake pads.
3) There is another thing. I think is something rod bush is blown. LOL. Can't really remember the name.
Last Sat was my first service after buying the skyline and it was shocking. :)
Thanks
https://www.sau.com.au/forums/topic/88172-shocks-brake-pads/
caster rod bush? it may cracked... get a replacement kit from whiteline.
for brakes, call RaceBrakes in north melbourne, they will recommend something suitable for you.
replacing your shocks, the price will vary depending what your expectations are on performance and features. I'd say go for coilovers (damper adjustable, height adjustable, pillow ball, etc.). But you could also select high end shocks and springs seperately to suit your requirements.
Ohlins == very good sh1t.
GAB shocks, kg/mm springs == good sh1t.
Nismo, HKS, TEIN == ok as far as coilovers go.
Hope this helps. Cheers B)
Bilsteins or Koni will set you back approx $250 per corner. (Springs are additional, about $100 per corner, I think)
Bendix Ultimates are pretty good bang-for-your-buck.
Yeah, probably the castor rod bushes. Get the urethane replacements.
Yes it is caster rod bushes.
Is it an important part of the car? I mean does it needs replacement urgently? Coz I know the shocks doesn't need replacement urgently.
Where can I get caster rod bushes? What brand and price range am I lookin at? Any recommendation? What is caster rod bush anyway? :)
Lol...sorry for the lame question. :D
caster rod bushes should be replaced sooner rather than later... you can buy urethane replacement bushes from whiteline for about $130.
http://www.whiteline.com.au
Thanks for tips mate. Do I need to replace both the bushes or just one? Currently the cracked one is on the driver side.
I'm also thinking of getting a suspension. I heard that Koni and Tein are the good ones. Are they costly? Any other recommendation?
Thanks
Hey Adrian!
I'll bring Golgo in on Wednesday and show you where the castor bushes are at lunchtime.
Your SAU membership gets you 10% discount at Racebrakes in Flemmington
http://www.racebrakes.com.au
Howard can fix you up :D
Actually - I think I have some Bendix pads somewhere in the garage - will bring them in tomorrow and check if they are the right size. They won't fit the Brembos - so pretty sure they are for a GTSt.
James
If you need a wheel alignment or any suspension work done, I suggest going to Centreline Suspension in Thomastown, they're awesome...
Haven't had any problems with the work they've done and been given excellent prices.. They're one of the only 3 places in Victoria I'd trust leaving our cars.. :)
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
