  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Only person I know with aftermarket ecu is EVLR33 - he bought Kens PowerFC before I could get some money together.
Can get a new PowerFC + HC from Nengun for $1700 delivered. If I knew that would solve the problem I would order one tomorrow & prepare to be castrated:)
Yep - that's the problem though cos you can't expect them to spend their time testing things without getting paid.
Might ask Brett about his PowerFC. Might also order a new harness cos I can get one for $600, just have to wait a few weeks for it to be made & sent from Japan.
I don't mind one that's not new, but I believe there is a bit of work installing them so it would make sense to put one in to stay, therefore better not to risk one that may also have problems.
Then again, depends on how much I can get a second hand one for - I already borrowed one off Ray last year just to check against the mess that the japanese owner had left - used to be able to stall the car by jiggling (hmmm...images non car related come to mind!) the harness near the ecu.
Yea , Yea , I'm here . Geez you whores make hard to catch up.
Phptf , stop trying to hit in Lauren , we were all here first.
Micko , I'm still thinking about the problem but I'm leaning towards AFM 's or wiring still .Don't think a new harness will cover that bit.
Cheers
Ken
Hey Ken - hope I didn't get you in too much strife today! Seemed like you relished the chance to take a break from your household duties anyways:)
Car was idling at 1100rpm on the way home with a/c on. Switched it off & revs went to 1300??? Started later & idling was at about 600??? What the?
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
