  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Only person I know with aftermarket ecu is EVLR33 - he bought Kens PowerFC before I could get some money together.
Can get a new PowerFC + HC from Nengun for $1700 delivered. If I knew that would solve the problem I would order one tomorrow & prepare to be castrated:)
Yep - that's the problem though cos you can't expect them to spend their time testing things without getting paid.
Might ask Brett about his PowerFC. Might also order a new harness cos I can get one for $600, just have to wait a few weeks for it to be made & sent from Japan.
I don't mind one that's not new, but I believe there is a bit of work installing them so it would make sense to put one in to stay, therefore better not to risk one that may also have problems.
Then again, depends on how much I can get a second hand one for - I already borrowed one off Ray last year just to check against the mess that the japanese owner had left - used to be able to stall the car by jiggling (hmmm...images non car related come to mind!) the harness near the ecu.
Yea , Yea , I'm here . Geez you whores make hard to catch up.
Phptf , stop trying to hit in Lauren , we were all here first.
Micko , I'm still thinking about the problem but I'm leaning towards AFM 's or wiring still .Don't think a new harness will cover that bit.
Cheers
Ken
Hey Ken - hope I didn't get you in too much strife today! Seemed like you relished the chance to take a break from your household duties anyways:)
Car was idling at 1100rpm on the way home with a/c on. Switched it off & revs went to 1300??? Started later & idling was at about 600??? What the?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
