  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Just tried putting the car in gear & pushing it to turn the engine - would probably work but it would be a 2 man job.
Paul - if you got time that would be awesome. I should be home by about 5.30 - I'll buy you dinner if you can come over (it will cost you 20 buxks in juice anyway:))
