Hey everyone.
I 2nd exhasut torque. $280 for a 3" one piece dump & front pipe is gold.
I've been pm'ing eriktofa behind the scenes. He's actaully not a bad person, just English is his second langauge so his posts are a bit mixed up. For the record, a tissue really did scratch his paint :P Seems like someone did a dodgy job painting his boot and the paint flaked off in places after a wash.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
DCIEVE
if they say no or give u weird looks about putting in a replacement pipe instead of a cat, just tell them its for race use off street, get them to make it up for u, and bolt it in urself when u get home :P ... what has your car got at the moment where the cat should be?
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
