  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
only you bring your wife :P ken.
she may be small but I try not to piss her off.
Last time she tried to poison me.:P
She wouldn't come anyway , thinks you lot are way too young to be hanging around with.
Or was she referring to the IQ when she mentioned under 25 ??
Cheers
Ken
Originally posted by Micko
Firstly - let me apologise cos my connection is f u c k i n g slow.
Secondly - sorry Neo, we thought you had left us cos the missus decided she was driving:)
Thirdly - whatever
Take along time for all those signals to get to South Geralton hey Micko. I know how it is.
:bahaha:
Originally posted by 33Spec2
i think nengun was the place EVL_R33 got all his stuff from he said it took ages 4 a reply and when they did reply they didnt even answer his question!
Brent ( thats Nengun ) gets an average of 300 emails a day from all over the world.
Give him a chance , he is good at what he does and it's best to be patient.
Also , don't ask him 10 questions cos he won't answer. One or two is all he seems to do .
cheers
Ken
Originally posted by Adrian_perth
neo, are u getting a titanium muffler? why not titanium catback :P
macka, i am asking fro pricing on trust/greddy cam gears
adrian :P
Yes it is a titanium cat back adrian.
Macka - You are lucky that he tells you about his secret car business. He would not tell u the other night:p
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
