  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
well I just wish that when I hit 28!
I'll have my own practice
with R35 GTR
a House
a wife and 2.5 kids :P
unlike you lot! :P
I got all that and more.
I practise on myself ( cos no one else will )
Have a house
Got a R64 GTR ( 2 x R32's )
Gotta a wife ( want one ?? )
No Kids , thank ****
cheers
Ken
yes neo, i am keeping wraps on what i am doing to my babe, hopefully all turns out well yall all see!
whhhhhhhhhhhhhhhha titanium catback? you building a drag car for hks or sumthin? how much that setting ya back what brand is it?
adrian :P
Originally posted by Micko
Shall I come & pick you up once you're drunk macka? You can be a right clint when you're pissed.
Ken - check you're last post matey cos methinks you forgot to fix a typo - better go back & sort it out;)
Ill give u that
But i got a better one...
Later....
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
