  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
What is it? i think 35 is the limit. Dont ask me 35 what, i dont know:rolleyes:
So u just in the wrong place wrong time eh? well it could have been a speeding ticket so at least this will save ure lic a bit. Look on the bright side of ahole cops.
THE GIRL'S PRAYER
Our Cash
Which art on plastic
Hallowed be thy name
Thy Cartier watch
Thy Prada bag
In Myer
As it is in David Jones
Give us each day our Platinum Visa
And forgive us our overdraft
As we forgive those who stop our Mastercard
And lead us not into Katies
And deliver us from Susans
For thine is the Dinnigan, the Akira and the Armani
For Chanel No.5 and Eternity
Amex.
paul,
dont think Aidwin got done for speeding. I think he got reamed for not having p-plates up.
so is the summons for speeding??
Id be taking the car to the place that did the tinting I reckon. getting them to provide a written appraisal of the level of tint, which you can show to the guys at the pits.
As far as the legal requirements, theres quite a lot about modification on the dotars and the dpi websites.
I think the dpi site goes into tinting and stuff...
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
