  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah paul - course I was happy:D
Will organise to go down again next wednesday & get steve to put a bleeder on to see if we can raise the boost down low (the factory solenoid doesn't tend to hold it too well above 12psi so I'm told).
After that I should be over the magic 300 mark so I will be even happier:D
Originally posted by Adrian_perth
i gonna pick it up tommorow, so all those that ordered cam gears hopefully you can be expecting an sms or phone call form me tommorow :P now to go an to some late night work on my car, re: fit blow off valve!
adrian :(
BTW , because I can't be assed reading back , how much did they end up being?
I got a set of JUN gears for the R and just trying to ascertain whether they were a good price.
Cheers
Ken
Wowow that was fun, 1 hour to get from leach to canning!!!!!!! bloody freeway i wish i could allow myself to break roadrules. I saw this girl in a red excel drving down the emergency lane talking on her phone and the cop next to me didnt do shait!!!
Hello, how iz all this windy morning?
Huh, 4th time broken into in 2 months last night! Smashed the sliding door AGAIN then decided that the VN looked alrigt so tried to get in (broke door lock completely) set the alarm off and bolted.
So yeah, already seen cops and all this morning. Hay, at least this house is eventful!
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
