Originally posted by GTS-t VSPEC
Niz, What was the OK for?
Micko is coming down - u repeated it about three times. So i was just acknowledging that i read it - u sound really excited - im worried for Micko sounds like u got plans for him :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Ken - I'm about to PM this guy back.... do you think I should???
Liz , you have had views from at least 5 people on this with some advice on what to do.
The ball is in your court with the next step.
What's he gonna do, get on a plane ?
As I said , if you feel bad , pay the return freight.
Cheers
Ken
yo yo, whats up :)
i just watched booty call hehe :(
for all those that went on hols, how wuz it?
russ: are u trying to copy me an buy a 17" monitor (dun worry bam bam dun it as well) bet ya u don't have flat screen heheh :)
bam : tell those guys talking shit bout u there not only gonna have to deal with niz, but wit me as well :)
adrian :)
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
