  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
rob 18X9 will fit fyne
i have 18x8.5 at front and 18x9.5 at the rears :)
adrian :)
only if they are the right offset.
You can get 18x9's under a silvia but they have got to be correct offset.
There are some 17x8's around that won't go under and only just get under a GTR
Cheers
Ken
wasnt going to wash my car anyway ..... jus tthat somebody suggested i wash it - but that somebody really needs to look in their own backyard before they pick on other peoples :) besides what a waste its only going to rain on it!! and its not tooo disgraceful yet.
haha Neos rattles hmmm when u fix ur own rattles then i'll be impressed :)
yeah i got my notes ready for you niz, or when i upgrade to bigger and better things :) i'll donate everything to you :)
the pleasure is mine when teaming up with you :)
russ are you sure it's 17 inches? i was told by some little fairies it's 1.7 inches :) ooooooooooooooooooooooooooooh damn nigga dat going down town he gonna get up in your face now!
adrian :(
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
