Originally posted by Nizmo
whos giving u crap about ur driving?
i dont drive to hard im a little softie :innocent:
Hmmm , spotted that you sneaked off to QLD.
Naughty girl , get back in here and whore.
:D :shake:
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cam, trust nobody?
im learning from that, i got a whole bucket load of abuse rammed down my neck about not trusting people, but i have my reasons not to
and they are all valid i think
as for the driving thing, they were pullin similar stunts, guy leading cruise was dumping it at redline in second in his car
probably sprayin gravel all over other cars, yet i copped the blasting cause im not a faveroute
i havent been in QLD for about 1/2 hour Ken :D
Geez Bel - what tha? driving too hard is not exactly something we give people crap about no cruises as long as u dont put anyone at risk. We prefer it to be done in quiter areas tho as not to give us a bad name ..... we are already stalked by the cops enough!!
Originally posted by BelGarion
im pretty slow, so is my car
Bel , enough with the negativity and self deprecating.
The trouble is that people on this forum are generally on here for info and humour.
When you continually post suicidal type postings it makes people uncomfortable.
As this is only a computer , nothing can be done over the net about your problem.
As suggested before by everyone in Qld , if you are always this way , seek professional guidance and it will not come from this forum.
cheers
Ken
if u cant put a power FC in an auto ..... what can u put in it?
A manual gearbox , then a Power FC.
Just kidding babe , just kidding
* oww , stop hitting me niz , oww , oww*
:D
Cheers
Ken
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
