  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by nostalgik
Hey Ken, Mark here again, rb25r32, just the diff nick and forum, thanks for the advice on the gtr's. If you do hear of any let us know..................................Cheers................Mark
ps I know your talking to Niz, well I hope so!!!!
Yes Niz and I have an understanding.
I lust after her and she calls me a dirty old man...;)
Geeee, this talking to you on two forums is doing my head in.hehe
Cheers
Ken
Niz, yeah had my 32 for over a yeah now, transplanted an rb25 in after a few months and a few other bits n pieces and makes approx 270 rwhp. Not much traction but absolutely love driving it. I was going to buy one of kens 'R's but fell through. Im looking for another r32 gtr right now. Honda drivers eh. Bit of a plague arnt they!. Commodore drivers like to irritate me like a rah but doesnt last long, just get out of there quick. Hey mayb I could borrow some of my sisters clothes and get of 6 point fines as well. That is almost worth cross-dressing for. But there are plenty of down-sides!!!!!
yeah i dont know why people put wings on their cars just doesnt look as good when everyone has them.
I don't use busses in perth troy i cant tell where they are going and get lost on them so i stick to the train and taxis.
-phil
Ken your GTR makes you the stallion on the forum-until you sell it then you can become a dirty old man. Thats what its all about.
Niz, my 32 isnt too bad ....................until you get into 3rd gear, 1st and 2nd are pretty much a joke. From the glance I got of your 33 your ride looks very choice ;)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
