See ya Kyles:)
Yep - we are sure that it never did it before Ken.
It started last night - we went from your house to the servo near me, he filled up & then it started playing up. Is there any chance that it could be associated with the pcv as aside from the immobilser, that is the only thing that was altered on the car recently?
Could be because the wing isn't on it any more:bahaha:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
See ya Kyles:)
Nah , car is back to the same as when I ran it. ie. pcv blocked , breather cleaner on.
Only change is the immobiliser. Are you sure all the wiring has been put back to std when you pulled the immobiliser
cheers
ken
Originally posted by GTS-t VSPEC
Damn, That was a pathetic Saturday night of whoring, took me 2mins to read back:p
Hope the cruise went ok:D
Ahh yes but some off us have a life and DO actually go out .
Think a lot might have cruised with epoch and I did the brownie point thing and went to La Cascade in Nedlands with the missus.
* Thinks , would rather be out cruising*:)
Seeya Paully and get off this damn puter and go on holiday:D
Cheers
Ken
hehe hey Ken .... me n Liz got into mischeif last night :D
We stumbled upon the South Australian Football Club and the club president was trying to pimp his guys out to me ....."What about this guy? hmmm do u like italians? ........ can i introduce u too? ..... Cmon just tell me which one you like and i'll see what i can do"
Had such a funny night ..... i think me n Liz really needed a night liek that :uh-huh: certainly got our minds off things! :)
anyway must go pick up mel for lunch in freo .... Liz maybe i should go bang on room 1033 and see if they are up yet haha i would imaginethere would be a lot of hangovers this morning!!
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
