  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
there are signs in SG of a person with a gun pointed at another person with his hands in the air on fences and stuff :D was funny. SG is a great place, just small and not much to do except eat nice food and shop, the only problem with the food is it can be very expensive if you dont like the local stuff. I think we spent like $100 in a steakhouse one night cos malinda wanted a steak, normally it'd be like $50 for both of us at lonestar.
Originally posted by Sneeza
I have had a brazillian - me and my best friend got one hahahaha FARK it hurt hahahah we did it as a joke... kinda....
owwwww
The thought brings tears to my eyes.
Cheers
Ken
Rob - hahah i saw those signs I took a pic... funny as hahaha.
Yeah - the trick is rob - you say you're flight crew or you want QANTAS crew discount..... no shit - drinks drop from $25 for two to $15... hahaha And we got a drinks free at this flight crew hangout for meals
Originally posted by Nizmo
ken babey ..... why would i go all the way to brazil for it ;)
haha i hear guys like big round butts there too. I would fit in well :D
Like big round things
Not butts though:D
Cheers
Ken
She said it when we were drunk hahaha And then I tried to get out of it later... but we went and got one (not at the same time... one after the other).... but jeez.... I think my tatoo hurt less.... (I also got that with her hahaha)
remind me to stay clear of your friends...:D
Cheers
Ken
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
