  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
there are signs in SG of a person with a gun pointed at another person with his hands in the air on fences and stuff :D was funny. SG is a great place, just small and not much to do except eat nice food and shop, the only problem with the food is it can be very expensive if you dont like the local stuff. I think we spent like $100 in a steakhouse one night cos malinda wanted a steak, normally it'd be like $50 for both of us at lonestar.
Originally posted by Sneeza
I have had a brazillian - me and my best friend got one hahahaha FARK it hurt hahahah we did it as a joke... kinda....
owwwww
The thought brings tears to my eyes.
Cheers
Ken
Rob - hahah i saw those signs I took a pic... funny as hahaha.
Yeah - the trick is rob - you say you're flight crew or you want QANTAS crew discount..... no shit - drinks drop from $25 for two to $15... hahaha And we got a drinks free at this flight crew hangout for meals
Originally posted by Nizmo
ken babey ..... why would i go all the way to brazil for it ;)
haha i hear guys like big round butts there too. I would fit in well :D
Like big round things
Not butts though:D
Cheers
Ken
She said it when we were drunk hahaha And then I tried to get out of it later... but we went and got one (not at the same time... one after the other).... but jeez.... I think my tatoo hurt less.... (I also got that with her hahaha)
remind me to stay clear of your friends...:D
Cheers
Ken
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
