hey everyone .... Sorry Liz already pissed
its been a pretty emotional day for me ...... ive gone off at my parents about giving Ben all the opportunites and me getting nowhere in life .... looks as if i may start training to be a marketing manager for their company ....... also ive asked about the possibility of me keeping the Zed and paying it off .... they want it gone before summer - and personally i really wan tto keep it as well ....... so hopefully i may have two cars. Although at the moment im in a SHIT load of debt and life aint too good .. hopefully things will turn around? i dunno
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
