  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by G0DF4Th3R
well id rather ship it coz its all small stuff and they are all under 400 bucks retail in Australia so you wouldnt be attracting any taxes etc.
i would carry it back but my bag will be full of some other stuff i bought, i have asked some of my friends to help carry some of my own things back to Perth :)
Cool!
PM Me when you set up and need/want spondoolie!
