  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well he drives like a grandpa :) i assumed it was an NA because even by normal standards ............ he was REALLY crawling! All iwanted was a bit of a drag ...... just a little one :)
So whats the deal with the engine of yours Cam?
Niz - stupid speeds starting with the number 2... something goes astray and i suffer major power loss...
i drive for another 100km or so and then pull out the plugs.. and nearly break down in tears... something has gone bang inside big time..
it's idling funny and doesn't have as much power.. i'm thinkin i've hurt a valve and that the injectors need checking to find out why it all went bang...
going to get it pressure tested to find out if damage has been done on monday hopefully..
Originally posted by Nizmo
tried to drag that Morley Car Audio or whatever its called Supra last night ...... must be an N/A ..... and whoever was driving it was driving like a total grandpa ..... must be totally weighed down with all those subs probably *shrugs* ....... i thought i was going to have some fun but nope ..... maybe he didnt want to suffer the humilation of a Skyline chopping :)
no Niz your right ive raced him at the plex he drives like a grandad lol nice guy but
well i expected something - i was prepared to lose but it wouldve been nice to have a little bit of fun ....... u think someone that has invested that amount of money for speed would drive more like a Supra and a little less like a barina ....... spose not my place to criticise someones driving ..... just disappointed :)
:grouphug: Cam ...... I had a bit of same deal with ZX .... not so much bang but i put my foot down really hard and it surged power and started coughing ...... had so many bloomin fuel and injector probs after that. Hope its nothing to serious ....... it can take the beating - its a Skyline :)
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
