yeah i was on a strict diet too - but i got depressed and had a sausage roll n cherry ripe ..... see if i can save myself at the gym tonight :D ..... must admit sausage roll tasted bloody good!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i dun like the church - Rise is ok depending on how ya feel - Metros is good now!! its packed and it plays RnB. But i love the Deen pity its only open til 1am :D paramounts ok if your extremely drunk and dont care its dodgy haha.
Donald Rumsfeld died and went to heaven. As he stood in front of St. Peter
at the Pearly Gates, he saw a huge wall of clocks behind him. He asked,
"What are all those clocks?"
St. Peter answered, "Those are Lie-Clocks. Everyone on Earth has a
Lie-Clock. Every time you lie the hands on your clock will move."
"Oh," said Rumsfeld, "whose clock is that?"
"That's Mother Teresa's. The hands have never moved, indicating that she
never told a lie."
"Incredible," said Rumsfeld. "And whose clock is that one?"
St. Peter responded, "That's Abraham Lincoln's clock. The hands have moved
twice, telling us that Abe told only two lies in his entire life."
"Where's Bush's clock?" asked Rumsfeld.
"Bush's clock is in Jesus' office. He's using it as a ceiling fan."
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
