yeah i was on a strict diet too - but i got depressed and had a sausage roll n cherry ripe ..... see if i can save myself at the gym tonight :D ..... must admit sausage roll tasted bloody good!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i dun like the church - Rise is ok depending on how ya feel - Metros is good now!! its packed and it plays RnB. But i love the Deen pity its only open til 1am :D paramounts ok if your extremely drunk and dont care its dodgy haha.
Donald Rumsfeld died and went to heaven. As he stood in front of St. Peter
at the Pearly Gates, he saw a huge wall of clocks behind him. He asked,
"What are all those clocks?"
St. Peter answered, "Those are Lie-Clocks. Everyone on Earth has a
Lie-Clock. Every time you lie the hands on your clock will move."
"Oh," said Rumsfeld, "whose clock is that?"
"That's Mother Teresa's. The hands have never moved, indicating that she
never told a lie."
"Incredible," said Rumsfeld. "And whose clock is that one?"
St. Peter responded, "That's Abraham Lincoln's clock. The hands have moved
twice, telling us that Abe told only two lies in his entire life."
"Where's Bush's clock?" asked Rumsfeld.
"Bush's clock is in Jesus' office. He's using it as a ceiling fan."
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
