  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey Rob,
carburetor -no. it's old skool 80s nissan EFI.
Its been a while - so the battery will be flat by now - but I think the major concerns are that there is a spark, and fuel being delivered, but the ****ing thing wont start.
It turns over,
*vroom**vroom**vroom**vroom**vroom**vroom**vroom*
but no *VrrrooooooooooooOOOOOoooom....buddabudda..*
well brakes have been done - no charge for parts :D
pick her up after work i'll get mum to take me.
Also done a bit of a draft mudmap for Sunday ..... gotta find the time to test tho should be able to do it saturday sometime - good chance to test the new brakes too. :)
well paul may want to change it .... but ive mudded out scarborough, gnangarra rd, swan valley, a few little scenic routes that i remember from long ago and are hoping are still there .... then into the back blocks of mundaring on what looks like some nice looooooong straight hopefully quiet roads :D
But its hard to do just looking from a map ..... kinda need to get in my car and pace it out now ....
wunder if my mums wants a drag on the way home *evil grin*
although way cars running id probably lose .... damn it
Anyway since nobody is here i might as well go "wing" shopping on the net :D
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
