  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :P
Originally posted by MrGTST
I believe R32's are quite a bit harder to find at the moment than the 33's..... You really want to have some idea in your mind about what you are looking for ( either 32/33 , manual/auto , turbo/non turbo, colour? , modded/stock , cheap(maybe needs a bit of work?) or one that may cost a bit more but is in better condition )and then start to have a browse around and just see whats out there..... plus there are a couple of guys on here looking to get rid of there skylines too dont forget :(
cheers for the help....
well im defianetly after a manual and a turbo(why buy a nonturbo) :P
colour aint really an issue
mods ain't to much of an issue as long as of got a good base to work from.....
got up to $20G to spend
Hi Niz ;)
yeah you would reckon that with almost 300 Hp at the wheels I could get into the 13's, pity I cant. I could probably whack on the bigger turbo like paul be running 350+ at the wheels and still tun that damn 14.1 :(
Well thats a good start ReVN211... thats basically what I did.... knew I wanted a manual turbo R33 with a GTR rear wing with no GTR badging.... had a look around the importers and found one in really good condition with everything I wanted, and it appears more recently it came with even more I didnt know about :)
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
