  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
you know MC did this whole thing when we had our drift day .... "oh MC isnt built for spectators ..... gotta discourage spectators etc"
Now they've got the PAS Driving event on this weekend .... and they've got it all advertised on radio to come and see it at MC
:confused: now thats a lot of advertising for a venue not built for spectators!
Niz,
I know what they said, but the reason they tried to discourage spectators is much more to do with the fact that large numbers of spectators require adequate spectator management - including risk managment assessment, crowd safety control etc.
the training day was not set up to cater for this - so I think that the real answer was that the event was not design to cater for spectators.
this event obviously has.
agh i hate that .... ask my boss if he wants me to set up tea n coffee for a meeting .... he says nah only going to go for an hour no point ..... two hours later ..... can you come up and get drinks for these people :) and bending over a boardroom table in this top was probably not a good idea!!
Yep , but only here for a short time.
Been to the accountant , the bank , waiting for someone to come then off to a Dyno Dynamics demo in Midvale.:D
* damn that avatar of Niz's is , err, disturbing *
Cheers
Ken
Nope , it's a dyno and they are setting up a new one for a tune shop in Midvale.
See a few days ago that you were gonna fly to the next drift day in the East.*sob*
This time I will leave the wookie and the fartmaster behind.
Honest...:D
Cheers
Ken
Originally posted by zanda
hey ken.
what's the money spinning business venture?
Gonna set up a pimp shop with the guys and gals of SAU working for me.
:D
Reckon it will go ??
hehe
Cheers
Ken
ps check new thread re drift day.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
