  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah more nervous Lee - terrified im going to look like shit haha
I can t have my car back in time either :D:( :(
On the upside im buying a FMIC for $400 ..... gotta get piping made up thos. Came out of a friends 375rwkw WRX he said i can have it.
Yeh damn beer, why do they got to make it so moreish.
How moronic is that nc113hiver chick in the wasteland, she starts threads about absolute crap. Dont wanna be mean and start deleting em though.
So i go round to Gradenkos last nite and he decides to take it for a test run. After the 3rd major speeding infraction it starts running on 5cyl again. So basically we thought the worst. Sat around and had acouple of beers while it cooled down and then went and checked the coil pack leads. One was not in properly. Theres nothing quite like the look on someones face when they think they need a rebuild :D
i dont want day to drag ........ wanna get out of work ...... didnt sleep to well last night a little bit on the cold & hungry side so im pretty zonked today oh well early night tonight for me.
I think i might cook chicken (first decent meal ive had in a while) for dinner tonight .... :D
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
