  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ok, an episode just for Paul :D
Episode 906: Business Still Sucks (part 2)
Marcie: " Breast feeding is a natural bodily function."
Al: " So is peeing. But you don't see me doing that in
public."
Lady: " Officer, someone's being mugged in the food court."
Officer Dan: " Tell someone who cares."
Episode 904(?): The Virgin Hotline
Bud: " I did something really stupid."
Al: " Oh, Son. You didn't marry, did you?"
Bud: " Dad, you probably don't know this but there's a big move
towards celibacy."
Al: " Know it? Hell, I started it."
Bud: " No, dad. This is no sex *BEFORE* marriage."
Jefferson:
" If you're a virgin
With hormones a surgin'
Keep on your undies
And call Bud Bundy"
Kelly: " Now, when people call, do you merely talk them out
of sex or send them a picture of yourself and scare the
pants back on them?"
Peg: " Here's one...'4 Weddings and a Funeral.'"
Al: " That's kind of 5 of the same thing."
Movie titles in X-Rated section of the store:
Schlinder's Lust
Booty and the Beast
Forest Hump
Silence of the Loins
The Joy **** Club
Mrs. Assfire
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
