  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey that shit aint funny
my girl never does things like that
but she does like bedroom antics so its all good
dude dont stress about the insurance now, its like if its meant to be then it will be.
i thought earlier that you meant your dad could organise it through contact for $1250 etc i was like fark thats cheap.
did rac say they will transfer the car for him and howcome you never sent me his car details
riaz, the rac was a bitch 2 him, they will not touch a skyline doesn't matter that he has been with them for like 25yr with 55 NCB. pissed me off
HBF was the cheapest at $1100 or $1200 the lady said 2 my dad but cant do me as second driver cuz i am under 21 :P
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
