  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Strich9 , I was,nt shittin ya. All the jap vids show the guys pullin on the h/brake , then loading up the clutch/revs...& DUMP. I've only tried it in wifes Pajeo...jury is still out on that one!
Don't tell me that your going to start dragging the pajero like saw 2 wednesday's ago :flamed:
Dont drink and drive... :thumbdwn: you might hit a bump and spill your
drink :D
strich9ine we run a 13.80 with 215hp so you should to better just keep trying
and practice those launches... our best time was when we did no burnout & run
a 13.41 went slower if we did skids :flamed:
