  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
don't lie riaz, you don't actually work man, you pimp out thailand whores to mexican midgets and bludge at your so called "day job"....
oh hang on, thats what I do ... *shrug*
okay i am back and alone again i c
doh well anyways i vegged all day long today
read a book mostly while at work
which is bad cos I got alot of work to do
terrible, just terrible.
yeah, it was a bit of a strange niche to get into, but now we've squeezed our way in, we're set for life man!
FOR LIFE! BWAHAHAHAHAH
anyhow, sorry I can't whore it up tonight, I gotta get some sleep so I can pretend to work hard @ my day job tomorrow.
Shall see you there.
Jason.
Oh, also, how do you like my cute new little duck avatar? I took the photo a couple of months ago @ my folks place .. random ducks came and stayed there for a week or so :(
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
