  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Aidwin if you can grab me a Boost Gauge i would be most appreciative ..... if you can find a black face one i would prefer but if theres only white i can deal with that :(
Also can you get SAFC II cheaper than $416?
