  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Riaz- just make it over 220HP at wheels.and ur project will be sweet
Yeah Riaz 220 at the wheels should give you a pretty sweet power to weight and gives some of us Skylines owners more than a bit of a shcok from the lights!!!
ok all the fustration is out now *clam blue ocean* on with the report that doesnt end .... yes it goes on n on my friend .... some stupid blonde bitch started typing it not knowing what it was .... but wait until she's typing it forever just because .....
Mike your odometer not working isnt something I know how to fix etc. it just proves the theory that no KM's are to be trusted on a jap car, which is what i told you anyways. and now the frgging thing stops working, its all too dodge.
maybe the previous owners C-red might be able to help fix it.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
