hey riaz, im back
Yeah i know about the number kms ect but i dont really care just wanna get it working some time in the future for now, I want to get my headlights fix, and back light fix, along wit the brake light in the Wing?
Did u find out about the part? i had alook at tring 2 open it but it doesnt look like it is glue togother and i didnt want to crack it
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
its too hard to explain over the phone so you gotta take it to autoworx along with the LED unit, which unscrews from the wing. and then you gotta heat it up and then open it,
and then reseal with sikaflex etc. but thats the cheapest way to fix it as they are expensive
not to sure yet, as im still looking at what to get, ken can get me a set of aus spec coilover for around $2,000, but i might just get aset of HKS HyperMax II as they around only $1,700 and with the shipping/gts ect it should only be alittle more than the aus spec ones, but im also going 2 look at the apexi ones 2
hmm so your p roject will basically be $1000 for the car $4000 for body repairs $2000 for spray
$2000 for Sr20
$5000 of labour and small things required for conversion
$1200 for wheels
yeah you will want to be driving that on the weekend from the look of it.
and your line will still beat it.
I think coilovers are major overkill especially when paying new prices for them,
paul might even have a shock sitting round for like $30 thats a better way to go.
i mean with your project car and all. Do you own mcdonalds by any chance??
your front lights arent in place right because they have been sikaflexed in place but whoever installed it originally.
so if you want to heat it up or cut them out and then mount them again, feel free, but i can tell you know its alot of messing around.
i would have done it, but its too much fiddling and also wiring the lights etc was all too much to do after all the stuff i did to make it presentable and clean and neat
riaz, its a project car which means it doesnt have 2 be ready untill along time away. I want to get the coilover 1st before anything else.
Im looking to get the a86 in about 3months do alot of the work myself and learn on the car.
I just wanna get the coilovers, with hieght adj. so it kind of solve 2problems
$2000 isnt much for u?
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
