Originally posted by GTS-t VSPEC
Yeah, he did run at 5:30, we were all done an then went to the info session:D
Annnndddd , what have you got to report , apart from the inordinate amount of spankers that stand up and plead there own personal case.
Hope the copper told em to shut the phuck up.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ken, just some interesting stuff with rim sizes increasing soon, we should all be able to run 9" rims:D Half-cages and harnesses legal if we get a permit for a two seater. Most things such as BOV and catch-cans are ok. Engine-management ok aslong as they don't see it:D
I knew 1/2 cages were coming in .
BOV's are interesting . What about the loud noise they make , surely they will get you for that instead?
Cheers
Ken
micko can now tell u all about his power run.
some useful info
pods allowed
fmic allowed
vented bonnets allowed
carbon and fibreglass bonnets no clear answer
ecu's no clear answer (but if they can't see it, its ok)
cams nope
injectors nope
internals nope
but they can all be yes if an emissions test is passed.
Russ, Yeah, looks good. The RB's are organising a 2F2F movie night, but they are such spankers that I'd prefer to do it seperately:D
Bit harsh pwptpf. I think they have about 400 members listed so there is a chance that a % are gonna be spankers.
I am sure if we tally up all the people on this forum in WA , we have a couple here.
Cheers
Ken
ps that's here as in here , not here as in on the forum right now , well not on whoretown right now , I mean.... ahh phuckit
Guest
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
