  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Angel !!!!!!
Babe , where ya been ???
We missed you and it's hard for only Lauren , Liz and Bailey to fend off all thes guys. They need help and now your back.
Hehehe:D
cheers
Ken
ps , oops , I forgot Kyles.
Hi Ken and Troy. Work? Don't ask. Still looking for real 8:30 - 5:00 type job. Have taken 8 weeks off part time to study. They asked me at work if I minded doing a few extra shifts on the days I am not studying. Now I am working 41 hours a week and studying 3 full days a week. And I am renovating my house.
Hardly time to wax my baby.
I WON in the car park war! You would be so proud of me troy boy. The bastard didnt even get a word in hehehe.
Kylie : "You where so rude to me calling me on the weekend. Troys car is worth more than all your cars combined." the idiot tryed to get a word in but then i said loundly "and.. you should have though before you bought 3 more cars you should have though about where you where going to put them. Im not moving house, I was here first. So you just have to find else where for your cars beucase your not getting my car space in the car port"
sucked in.. dont mess with kyles .. hehe i was cracking up laughing . Hes awnser was after a few seconds of silence. Ok. So i said thankyou and hung up hehehe..
Guest
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
