Hi all,
Item:
I have available the following:
- Fully built Jaycar boost control kit,
comes with cable, h/c and controller - $150
- 480cc s15 injectors - $280
- Airflow meter off s15 - $50
- Standard airbox off s15 - $70
- Trust Airinx air filter - $150
Pm or reply here if wish to inspect goods.
Item Condition: all parts are in good working order
Reason for Selling: have decided to mod car & using pfc with boost controller
Price and Payment Conditions: Prefer direct transfer or pick up
Contact Details: pm or reply here
Edited by mac30
https://www.sau.com.au/forums/topic/88241-parts/
do your or anyone else know if the injectors are a straight/direct fit into an rb30 with the rb25de head? Are there only four i'm guessing?
cheers!
Edited by mr_rbman
https://www.sau.com.au/forums/topic/88241-parts/#findComment-1594640
