A few of us are heading out to Wakefield for some track time on Friday if anyone is keen. Jayce will be bringing the R32 and I will have the S15 as per usual. Its an Open Practise Day so not competitive just a chance to drive your car like you want to in a safe environment and free from the Police.
Meet at 7:30 at Shell servo near Exhibition Park.
Let me know if you need any more info.
https://www.sau.com.au/forums/topic/88365-wakefield-this-friday-23rd-sept/
As Camma said,I'm going along for a quiet lap or three...Actually,it may not be so quiet;anyone remember my 32 before it had the road legal exhaust fitted? Maybe,just maybe,I might have the full Nismo system on it come Friday...Anyone want blown eardrums?!?
id come if sum1 wants to take me?? :) jayce...pleaaasssseeeee
Sorry Gus-mo,but I'll only be there for 1/2 of the day,and it's too much arsing about organising passengers...
Im tempted to come just to hear that exhaust again... oh how so damn good it sounded
Yep,it's something else! Nik's one of the lucky few to hear said exhaust note...and still be able to hear afterwards!
ooh ooh me me! i want blown eardrums! i actually havent heard your nismo system, i believe im missing out on something wonderful.... :)
Edited by SKYLVIA
R31_silo2 if you want a lift just let me know 0407 202 348. I will be out there for most of the day (unless it rains in the arvo).
I hope you change exhausts Jayce, sounds like I am missing out! :D I was going to do my usual trick of changing tyres out there but might chuck the semi's on tonight.
No worries Gus. Thanks for taking the pics.
Was a pretty good run with Jayce and I rounding up most of the cars out there. I just want the owner of the R33 GTR to give me a steer.
We will be out again on 21st October with a few more cars.
  • 4 weeks later...
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
