lol.. HCL is not going to eat through the whole concrete like in the movies !
I ended up using Caustic Soda.. diluted in water.. worked pretty well... similar to HCL probably (couldn't find it at the hardware store, it was probably there somewhere, or maybe they aren't allowed to sell it anymore).
Caustic Soda is pretty heavy duty so have to be careful you don't get it in your eyes, etc..
cant buy proper HCl nowadays - apparently something to do
with it being one of the ingredients terrorists are after.
we use it all the time in teh labs, only universities, etc etc are
licensed to buy them.. it doesnt burn through stuff.
Acetone may work...
Just up in the Bursons near work - Selleys seem to have a couple of products specifically for cleaning oil-in-concrete.
Cement / kitty litter only work for the initial spill, to absorb the liquid oil. Caustic soda is actually available in supermarkets (it's basically Draino). DO BE CAREFUL - it is highly corrosive, and will generate massive amounts of heat as it dissolves in water (the water can be near boiling!)
you guys got no idea, hydrocloric acid 32 percent, un diluted is the only way to go.
funny, we spilled some hydrocloric acid on the concrete of my work today and it reminded me of this thread :O it doesn't eat through the concrete, it does bubble for a while after being spilled, it will clean the concrete good but will stain it!
CLR is actually really good, acetone doesn't do much.
Acetone may work...
We get HCl for our dry delivered Batteries.
Funny you mention people using it for different things, as some druggo looking bloke wanted to buy a 5 litre container off us. He didn't really care about the cost... <_<
Cheers
Sumo
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
