Notice one of these up on ebay for sale today while doing a search for 'nismo' products that are for sale on ebay.
http://cgi.ebay.com.au/NISMO-BLANK-KEY-SKY...1QQcmdZViewItem
Just wondering as to exactly what these do and what they are used for.
If it is actually a key, how would it be used to work with the ignition, key door entry and boot lock?
https://www.sau.com.au/forums/topic/88488-nismo-blank-key/
umm.....You need to get them cut first mate. lol
https://www.sau.com.au/forums/topic/88488-nismo-blank-key/#findComment-1597179
HAHAHAHAHA :P
Sorry, can't help but laugh at that one :lol: I've got one of these keys - adds major bling factor! Much better than the dull black keys from factory.
However, they do not really look that colour... you'll find it is much more metallic and not as much gold...
https://www.sau.com.au/forums/topic/88488-nismo-blank-key/#findComment-1597241
just a thought. some of the 34's I have worked on had a factory immobiliser chip in hte key. may want to look at this BEFORE you buy the key as it will have to be programmed to teh car.
https://www.sau.com.au/forums/topic/88488-nismo-blank-key/#findComment-1597850
If you get a key made up from bunnings or other places it will not work. The person there made it twice and it wouldnt open the car. You have to go to a PROPER locksmith. You do not want to f**k up the cut on a nismo key.
Edited by krzysiu
https://www.sau.com.au/forums/topic/88488-nismo-blank-key/#findComment-1609409
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
