  • Replies 134
i live in Sandringham, but just saw this thread... don't see many skylines his way, so a dark blue S2 will def stand out. I'll keep my eyes open for ya for sure.
i've seen a previous thread where a 32 GTR in brissy was stolen, but it was some sweet ride, custom this and that... top car. Anyways, ppl who stole it were just cruising around in it, being hoons. And over a week or so, ppl kept seeing it and stupid driving. I can't remember what happened, i think it might have been used in a bank robbery but they f**ked up somehow, and abandoned their "getaway" car.
anyways, point is, if you're lucky, we'll get a few sightings here and there, and try and track 'em down..
oh, that's the other thing. SAU ppl who spotted the GTR were following the it, but apparently the driver caught on and got spooked for a few days. So try and stalk stealthily if you see it :)
Really sorry to hear about your ride mate....
That's really F$#@ed up and makes me mad....
Iam from the northen sub's so ill keep my eyes open as well...
I think people who own nice cars such as skylines really need to think about how they are going to protect it from low life sum bags..
I think satellite tracking is far more effective then simple car alarms...
I have a quick track satellite tracking system in my car and I would recommend it to any one...
Also the company who I work for has a similar device which we use for data logging and can also be tracked via satellite with software supplied with the device. Fitted to their trucks and has already proved it self to be very worth while investment...
We had a Ute stolen from our yard at the start of the year. They broke in on the weekend and stole the Ute and used it for ram raids. Come Monday morning we noticed it was missing. The first thing we did is notified the police and then we fired up our pc with the tacking software and found the car with in sec's... Told the cops where it was and BANG got them..They had parked the ute at their house in the garge with our plates still on it... Just show's how dumb some people really are...
Any way good luck with it mate i hope it turns up.....
roughly how much does that kind of satellite tracking system cost?
It certainly sounds like a worthwhile investment!
The Quick Track system by memory is around the $2000 mark installed, and then there is a $365 a year charge for the monitoring...
Also I must point out that in the event of your car being stolen you will get a phone call from the police or quick tack confirming that your car has been stolen and that police are on there way to intercept the vehicle. Also they can stop that car via satellite...
Also your insurance should be a lot cheaper having the system.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
