lol the R33 actually looks better in Ute form than it does as a regular car. R32 ute's been done in real life, so the chop dosen't seem as realistic, and the R34 looks good too, but not as good as the R33 ute.
Thanx guys. The r33 almost looks like a commodore ute hehe. I remember seein an r32 chop in a drift vid, it looked good up untill they showed inside the tray, looked dodgy as. I might try makin a few 4 door hatches like the old school r30 hehe.
33 looks neat, the 34 looks like it shoulda alway been a ute but as for the 32 it doesnt really look any different at all..just looks like someones taken the bootlid off it's boxy ole ass :P
ROLF! yeah the 32 is the odd one out, saw one in a drift vid and thought it looked pretty neat ;)
Well slap on a "Real Gaijin Drive Utes" sticker, a few more Asahi stickers, a CB antenna or three and off you go roo-shooting R32 style :)
:lol: ROFL :lol: Hell ya, hi-tech hillbillies hehehe
