Hi guys, just made 340AWKW at CRD today with our street exhaust.
I have yet to see the Dyno graph but jim said the car made more low end about the same mid range and more top end with the JUN plenum and QF45 throttle body.
tomorrow i'm going over to but the 4"exhaust on and then we will do another power run and just check it over to make sure everything is ok!
Last time the race exhaust made another 30AWKW on top, with out any tuning.
I'll post up again later to tell you how it all goes.
Cheers
https://www.sau.com.au/forums/topic/88735-340kw-at-the-wheels-on-gt-ss-turbos/
Hi,
we ran the car up again with the 4" exhaust today.
we made another 20AWKW =360AWKW
I beleive the problem is now that the airbox we had made(which is designed for max power with the headlight out).Could now be starving the car of air with the head light in.
The car is pretty mad to drive!
The next mods to the car with be a new intercooler and a fibreglass funnel to the airbox from where the head light is.
A BIG thanks goes out to Jim and the gang at Croydon Racing Developments for the great job tuning the car .
Another reason for not making more power with the big exhaust is that the turbo's can't keep the pressure up with the new plenum.
I would like to try a set of GT-RS turbo's on the car.
I think that the good old GT-SS turbo's are pretty much out of puff!!
we'll see what has to be done to make some more power down low.
Cheers
Sorry i forgot to add that was on 22psi down to 21psi andf running BP 98.
shit so thats 612hp at all fours or am i mis-calculating :)
i dont doubt the figure i just wondered if i worked it out right and damn thats impressive numbers for little low mounts :D
good luck
Brad
Sorry that's not right.
22>21 made 340AWKWs quite exhaust
22>21 made 355awkws big exhaust.
27 psi made 360big exhaust
as you can see the turbos are out of puff by then anyway.
I'm not sure how much that is at the wheels in HP.
Again thanks to the Guys at CRD!
Congratulations :D
Looks like Jim is definitely on top of these GT-SS turbos :O
What are you plans for the car? I wouldn't put a pair of GT-RS on a stock capacity RB26 if I were you. The car won't be anywhere NEAR as fun to drive.
Full mod list?
i belive this car runs a JUN 2.7lt strocker and JUN plenum i would like to see what GTRS can do
I'm not quite sure what an extra 100cc would do in spooling up the GT-RS, but I'm interested to see if 600hp is willing to take the chance and show us :D
All the UK tuners (who have been testing with the GT-RS's for the last 3 years) readily agree that you need at LEAST a 2.8 stroker or preferably a 3.0 OS Giken kit to get the GT-RS's to spool early enough for a road car.
From what I've noticed building a 3ltr then comparing it to the 2.5 and 2ltr, it appears for every 500cc increase you improve spool by ~600rpm.
Its the torque that makes the biggest difference.
Edited by Cubes
I don't really understand the following that these GTRS's have on an RB26 , I cant see the point of extra capacity to excite turbo's that are so so to start with . 2530's would have far better response than GT-RS's (GT2871 52 trim's) so what gives ? If someone went to the same lengths with these turbo's (2530) as WilliamsF1 did with GT-SS's surely the torque at the wheels would be adequate and very progressive . I think Gary mentioned some good times with them but cant I remember the numbers .
Cheers A .
Hows it going 600hp
Do you think you have found the limit of the GT-SS
at the 360awkw? (great effort by the way)
I hate it when people talk what boost by when (cos it really has no relationship to power and torque) But i would be interested to see the torque curve you achieved as to me it's the most important thing as it's what drop you back in the seat and keeps you there lol.
pete
ps great to see you posting results again cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
