Congrats to Man_in_bulk....he took out the final round of the state champs at Eastern Creek this weekend, winning the 2005 championship in the process (not to mention a very impressive 1.48.8 lap time....)
Congrats to Geoff and the rest of the support team at BSM including Sydneykid!
Whats more.....another SAU forum member (if only just :D) came home 2nd MB.Motorsport :( Shame he's in a commodore but he might upgrade one day ;)
Honourable mention to road_and_race who's GTR finished 5th in Class A pipping me by 8 points (I ended up 6th). And haw001 who ended up 10th (thats what you get for only entering 1 round :D)
Can't wait to get out there again next year and give it a real shot :D
https://www.sau.com.au/forums/topic/89008-skyline-wins-2005-nsw-state-champs/
yes, congrats to the BSM boys!
Well our season in prod sports came to a sad end with the porsche being heavily crashed in practice :D Turn 1, EC, 180kph, inside wall... not good. car is totaled. Not sure if Rob and our little band will be back next year, but if not i will offer my strut brace and services to you duncan :D
nah I was coming around to lap him Geoff.
HAHAHAHAHAHAHA
Richard that really sucks. Did the tail come out in turn 1 or was there a nudge. :) I guess its a reminder....only race what you can afford to loose :) at $9k a GTR is in my budget.
Maybe its a sign he should be picking up one of those old spec carerra cup shells.....supercar pace at about 10% of the price
yeah tail came out at turn 1 on the throttle, arse snapped around and fired him into the inside wall, car is quite badly damaged. the quote from someone in sydney was $76K in parts + lots-o-labour. Rob has a plan though and should have it back together for a fair bit less than that. Porsche (germany) apparently will take the old shell back, crush it, credit him towards a new one and send a replacement 05 cup car shell complete with cage etc back. He can do this as it was bought as a Cup Car.
The funny thing was the car was not behaving as Rob wanted yet he still managed to qualify 5th with a 1:40.1. It would have been a great weekend.
Richard was that the cup car missing a lot of the front end parked up-hill from the control tower on saturday? or another fence/PCC car?
I was at turn 4 and saw a bigggg lose in the first race on Saturday cold tyre oversteer and disappeared stage right....
any fotos?
Whats more.....another SAU forum member (if only just :D) came home 2nd MB.Motorsport :)  Shame he's in a commodore but he might upgrade one day ;)
Can't wait to get out there again next year and give it a real shot :)
Duncan,
Thanks for the mention, it's a shame I missed the last three rounds but I hope to have a full season next year.
I would also like to congratulate Geoff, Phil and the boys at BSM and hope to see you at the track soon.
Karl
kinda, you can't comply a rally import for full road use, but you can drive them to events, practice, shows, mechanics etc etc. Now the 15yo rule is finished the prices on 89-90 gtrs are more sensible again, heading back down to 400-500k yen ;)
One of teh guys at work was telling me about the rally car for road use thing, sounds interesting.
So where do you get these "unregisterable" skylines from anyway?
Any car can be registered as a rally car as long as it has a CAMS log book and has been accepted. But the most common way to do it is to import a car from Japan for Rally use. Full details are on the DOTARS site
Thanks for that info
  • 1 month later...
Both Production Cars (3E) and Improved Production (3J) allow GTRs these days, I'm pretty sure it is national from CAMS not a state based thing. We've also had wrx, evos, mazda gtrs running with us at various times
Production Cars I think is only in NSW and National series but you have IP in QLD don't you?
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
