Hey guys. I was wondering if anyone found them selves in a similar situation to me and may be give me a hint at what it was.
Anywho, after trying to start my car, I noticed that the car started without any probs, but all the electricals inside and outside including the deck, instruments, cabin lights, brake lights, etc did not work. The only thing that worked was the far light and the high beam (separate circuit I presume).
The first thing I though of was fuse, so I get out my voltmeter, ready to start checking. After testing the brake lights and pumping the brake for a while everything just came back on suddenly (coincidence me thinks). So I'm a bit stupefied and it has only happened once more in the past 2 weeks.
So I'm assuming it could be a stuck relay switch somewhere, or somethin similar.
A friend of mine was having a wild guess that the computer turned everything off for some reason - but we don't give too much credit to that theory.
Any advice / similar problems.
Appreciated!
:P
Edited by homerz
https://www.sau.com.au/forums/topic/89308-funky-electrical-issue/
yeah stay away from that "computer took over my car" kind of thinking - that was the mentality of the early 90s..
if you have checked the fuses under the dash and inside the engine bay, then either could be a faulty relay or a loose connection somewhere
an auto electrition could probably find the problem in less than 30mins next time it happens..
good luck,
Warren.
Thanks for the hints guys, I think I'm still sticking to my initial instinct regarding the relay. I suppose an auto electrician is the way to proceed. I just thought its something that people have experienced before. I know electricals are tricky at times, like chasing a ghost in the machine.
Thanks again.
bad earth some where maybe?? So many things to check.
Earth to battery is it covered in acid (clean it if so)
there is also some fuses and relays in the boot (just under the rear pacel shelf)
Check the wires under the dash, as you said that when you pumped the brake it all come back, so maybe under therem there is a broken wire.
Next take it to any auto elec $50 - $100 should cover it.
I would check the main connections and the obvious things first.
I highly doubt its a relay, as it would not control that many things.
You have to get it playing up to take it to an auto elec. Otherwise they will check the main things, then have to go through the lengthy process of checking everything.
Cheers
Matt
unsure if skyline is same as a s13
but i had this problem once in a silvia....i was driving and everything died exept for the lights.
on the possitive battery terminal there is a plug with a couple of wire running to it,with spade connectors on the ends
put them wires out of the terrminal clean and push back in so there is a nice tight fit
hopefully that helps
cheers softy
  • 3 years later...
Maybe a faulty / failing connection of one of the fusible links onto the battery.
I just recently had this exact same problem - turned out it was the fusible link after all, except mine was coming on when i revved the engine past 3k rather than the brake pedal.
-D
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
