Greensborough/Mill Park/Heidelburgers
  • Replies 115
  • 4 weeks later...
Hi Guys,
I'm from South Morang.. well actually Mernda (nobody seems to know where that is) I drive a white S2 R33 with White 17's. I hardly see any other Skylines around?
I drive down to Mill Park and Bundoora a fair bit - I must just miss everybody :P
I used to work at TRUenergy in South Morang on McDonalds road there..
I'd be in for a mini local meet if guys are keen...
Cheers
Hi Guys,
Cheers
I remember seeing that quite often.
If there is a meet Sunday I'll be there, but I think I'll be at the Barbie Saturday too.
yo r31silhouette I saw TWO 33's with white rims today around Epping :D
I think one of the plates was... tmb.. or something.. I don't know, I was distracted by all the cops at the railway crossing near Lalor safeway.. think there was a hit n run at around 6ish and the victim had a pram/stroller caus they put it in the back of their paddy van. :)
There's an imposter! :ban: My plates are TTB so I'm guessing 'TMB' was possibly me... I'm always around Epping at 5:30 - 6ish.. If you see me.. gimme a wave!! :)
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
