I am taking the day off work and heading out for another round of sprints this coming Wednesday. Just letting everyone know incase anyone is keen. Will get plenty of track time and you get to run the Sprint and Clubman layout. Should be fun!
*EDIT* Title should read 05/10/05. Oops
https://www.sau.com.au/forums/topic/89326-qr-sprints-wed-050905/
Jase,
I plan on going - however - saw the weather last night and they reacon rain Tuesday and Wednesday. <_< If it is still looking OK I will definitely be going.
BTW, its a free practice morning on Wednesday as well. I'll probably go out early just to see how the car is going. If all is OK, I'll run the sprints as well. :)
Cheers
Peter
hmmmm, better not rain. This will probably be the last hit out for the year for me, Ipswich heat scares me :cheers: See you there Peter! I will get out nice and early if its free practise before hand! Might have to bring a jerry can though. . . .
It $55 for a license if you don't already have one (it lasts 1 yr), and $75 if you prepay or $95 (I think) if you pay on the day.
Crap my Ipswitch raceway licience ran out last month....
How crap is that......
Ill have to take a pass.... sorry.... I just bought a new set of golf clubs today and if i spend anymore money this week ill be shot by the mrs.....
Good that you pointed that out cause i forgot all about the licience bit....
Just like i forgot my 4WD pass on the beach last week end....
Had a sticker from last year up on the windscreen.... Oh well i dont get fined tho....
Looking the goods atm, according to BOM.......
IDQ1009002
BRISBANE METROPOLITAN AREA
Fine. Light to moderate SE to NE winds, tending NE to N on Sunday.
Brisbane for Sunday ... MIN 17 MAX 31
Bayside for Sunday ... MIN 15 MAX 28
UV INDEX - 7 [High]
Monday ... Mostly fine. MIN 18 MAX 32
Tuesday ... Possible shower or storm. MIN 17 MAX 28
Wednesday ... Fine. MIN 17 MAX 27
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
